Collecting dust http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=9961 |
Author: | old man [ Fri Dec 22, 2006 9:29 am ] |
Post subject: | |
I'm installing a dust collector and thought you folks might like to see how I'm approaching collection at some of my machinery. First is the miter saw. The hood can slide right and left far enough to keep in a useful position cutting 45's. ![]() ![]() ![]() ![]() Then, probably doesn't qualify as a common lutherie tool, the lathe. I just attached a shelf on the back of the stand, mounted the hood on a piece of wood and can position it anywhere along the shelf and clamp in position. ![]() ![]() And I replaced the 2 1/2" port on my thickness sander with a 4" port. ![]() I'll be coming off the collector with 6" hose and going to all the machines with 4". Thanks for looking, I'll show the whole system when I'm up and running. ![]() Ron |
Author: | Rod True [ Fri Dec 22, 2006 9:49 am ] |
Post subject: | |
Cool. Looks good Ron. That's really going to suck ![]() |
Author: | old man [ Fri Dec 22, 2006 2:47 pm ] |
Post subject: | |
Suck is right! I've got a Penn State single stage with a 1 micron canister. 2 Hp, 220v, 12" impeller. Supposedly pulls 1500 cfm. I had to run a 220v circuit to it and I want to thank Bruce for talking me through it. I'm going to try the trash can thing to make it a two stage collector at a couple of different points. Pics when it is all finished. Maybe tomorrow. Ron |
Author: | Andy Matthews [ Sat Dec 23, 2006 4:31 am ] |
Post subject: | |
Here's the progress/finished pics of my dust collection system... I need to sort a hood for the pin router and get some hand tool adaptors for using at the bench. pic1 pic2 pic3 pic4 pic5 pic6 pic7 pic8 |
Author: | Serge Poirier [ Sun Dec 24, 2006 6:03 am ] |
Post subject: | |
Nice set up Ron, where did you buy that thing? A couple more hours and we're talking "live" buddy! ![]() Cheers Serge |
Author: | old man [ Sun Dec 24, 2006 7:16 am ] |
Post subject: | |
[QUOTE=Serge Poirier] Nice set up Ron, where did you buy that thing? A couple more hours and we're talking "live" buddy! ![]() Cheers Serge[/QUOTE] Hi, Serge. Those hoods came from woodworker's supply, I think. Most of the woodworking supply houses have them. These are the largest I could find, about 16" wide. Looking forward to hearing from you, my friend. Ron |
Author: | crazymanmichael [ Sun Dec 24, 2006 7:31 am ] |
Post subject: | |
ron, you are certainly getting there. but considering how i am always tinkering with my arrangement i often wonder where there is. what size duct do you have coming off the machine? if it is 6" try to take the 6 in to the machine and install a 6 in take off. on the thichness sander a wye and 2 x 4 in takeoffs a la performax will work better than the single 4 as well. the thicness sander will be your single bigest dust collection problem. jam, you have done a beautifull job of dust control arrangemnet. i would suggest that you try to straighten the flex hoses as much as possible. the contortion on the bandsaw will reduce the collection efficiency as will the sharp bend on the edge sander. |
Author: | Serge Poirier [ Sun Dec 24, 2006 7:32 am ] |
Post subject: | |
Thanks Ron, a few less minutes to go! ![]() |
Author: | Andy Matthews [ Sun Dec 24, 2006 11:42 am ] |
Post subject: | |
[QUOTE=crazymanmichael] jam, you have done a beautifull job of dust control arrangemnet. i would suggest that you try to straighten the flex hoses as much as possible. the contortion on the bandsaw will reduce the collection efficiency as will the sharp bend on the edge sander.[/QUOTE] Thanks ![]() I'm currently trying to keep on of the massive amounts of waste that the pin router creates! I need to sort a big funnel like the one in the first post methinks. |
